132 Users Online (130 Members):
Forums >> Revit Building >> Technical Support >> Room Tags Filtered?
2 Posts No Rating |
Is there a way to have a room tag that will stay visible with a label inside it that can be turned on or off in one click? I am trying to make rooms with tags that include people's names, but I need to be able to hide the people's name for certain meetings.
Thanks
You can use object styles or the Yes/No parameter.
http://revitbeginners.blogspot.com/2006/03/family-visibility-control.html
2 Posts No Rating |
Senor Duarte,
Your advice was excellent. Your blog/ website is intriguing and informative and I will certainly continue to visit as I have questions. I will also reccomend it to others in need of solid advice.
Thank you.
To follow up:
Every aspect of your suggestion from "Yes/ No Parameters" worked until the very end. After creating the yes/ no parameter, creating two distinct family types, and checking one and unchecking the other...
the object (in this case the object was a label text called "Doctor Name" did not turn gray. I loaded it into the project anyway and it showed up as a question mark, except it was not a text editable label (like a room name would be).
Can you put the icing on this one?
Is it a shared parameters issues?
Thank you,
Stephen
Works for me. See attached.
ROOM TAGS |
Fri, Jul 29, 2011 at 8:25:58 AM
Select room tags; copy rooms to new phase |
Thu, Jun 29, 2006 at 7:19:48 AM
Room Tags on Demo Plans |
Mon, May 9, 2022 at 3:23:12 PM
Want to see Room Tags but not Rooms |
Wed, Oct 5, 2016 at 11:37:51 PM
Vanishing room tags |
Tue, Sep 6, 2005 at 5:54:21 PM
Members: | 2030612 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
