67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimensioning to the centerpoint of an arc
Tue, Aug 15, 2006 at 8:18:20 AM | Dimensioning to the centerpoint of an arc
Toddh
I am trying to snap to the center point of an arc while dimensioning using the linear or aligned dimensioning tool, but I can not get a snap point so that I can locate the centerpoint orthogonally. Can I snap to a centerpoint while dimensioning? If so, how?
Tue, Aug 15, 2006 at 8:54:03 AM | RE: Dimensioning to the centerpoint of an arc
Revit doesn't seem to dimension to arcs in a conventional manner. When I've had problems like this, I've added invisible lines and used those. NOT the best solution but it will get you by.
Tue, Aug 15, 2006 at 10:15:19 AM | RE: Dimensioning to the centerpoint of an arc
coreed
coreed Avatar
4 Stars: 16 Votes
here is some info from the Revit Beginners blog: 1. Draw an arc (wall or line doesn't matter). Goto its properties and you can check "Center Mark Visible" if you need to dimension to the center point of an arc. HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Aug 15, 2006 at 11:46:21 AM | RE:
Scott Davis
3.5 Stars: 3 Votes
Quoting Toddh - 2006-08-15 08:18:20
"I am trying to snap to the center point of an arc while dimensioning using the linear or aligned dimensioning tool, but I can not get a snap point so that I can locate the centerpoint orthogonally. Can I snap to a centerpoint while dimensioning? If so, how?"
Turn on the Center Mark in the properties of the Arc Wall.
Tue, Jul 29, 2008 at 3:02:57 PM | Dimensioning to the centerpoint of an arc
CADVANTAGE
oK Revit-eers,
How do you liniar dimension the radius point of a radius dimension itself: say in this arched opening in a wall in elevation.
There is no center mark check box. My sketch could on a in-place opening, but it turns off when I finsh
Tue, Jul 29, 2008 at 3:09:34 PM | Dimensioning to the centerpoint of an arc
CADVANTAGE
The wall and line work as far as showing center mark work great. But what if you want to linear dimension to a radius point dimension?
Tue, Jul 29, 2008 at 3:50:19 PM | Dimensioning to the centerpoint of an arc
mhans
3 Stars: 10 Votes
You could always draw a reference plane that passes thru the center of your arch opening. Dimension always snaps to ref. plane.
Motto: "No Post left behind"
Tue, Jul 29, 2008 at 4:11:55 PM | Dimensioning to the centerpoint of an arc
CADVANTAGE
I know I can add that but it is more of a graphic thing lining up tick marks. Just hoped there was a key method I did not know about grabbing that blue grip that shows when you select a rad. dimension - but thanks for the quick reply!
dimensioning to a center mark of an arc
Wed, Jul 5, 2023 at 3:13:09 PM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:52:57 AM
Divide arc by length
Fri, Sep 7, 2007 at 6:17:46 PM
ARC LEADER NO TEXT
Thu, May 2, 2013 at 10:36:04 AM
Arc Walls with curved top?
Thu, Aug 7, 2008 at 2:04:21 PM
Page generation time: 0.2399
