29 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> aligning RPC s?
Tue, Aug 15, 2006 at 8:13:29 AM | aligning RPC s?
mmetin
mmetin Avatar
how can i put the car on the ramp?...command "host" didn't work.
Wed, Aug 16, 2006 at 11:15:13 AM | RE: aligning RPC s?
jfurlong
try this select the car edit the family inside the family - settings familycatagory and paramaters choose the family catagory its part of unclick always vertical. that should work
Thu, Aug 17, 2006 at 3:00:07 AM | RE: aligning RPC s?
mmetin
mmetin Avatar
i added a parameter "angle"..and cahange it to 20 degrees but it didn't work...i also couldn't find any thing about being always "vertical" in family settings...thanks for help.
Thu, Aug 17, 2006 at 3:17:57 AM | RE: aligning RPC s?
jfurlong
you were looking in the wrong place see the image below.
Fri, Aug 18, 2006 at 8:16:18 AM | RE: aligning RPC s?
mmetin
mmetin Avatar
thank you very much..it's ok now.
Fri, Aug 18, 2006 at 8:18:50 AM | RE: aligning RPC s?
jfurlong
glad i could help, that works for all families not just rpc,
Rpc Creator made Rpc can't load
Wed, Oct 24, 2012 at 5:12:33 PM
RPC PRoblems
Thu, Nov 17, 2011 at 7:48:36 PM
ArchVision RPC Component not showing in Views only in Renders.
Fri, Sep 4, 2009 at 9:13:29 AM
2009 RPC files
Thu, Sep 9, 2010 at 2:47:13 PM
RPC Files
Tue, Apr 28, 2009 at 5:45:41 AM
Page generation time: 17.6738
