58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Project
1 Posts No Rating |
Hi there
I am a new Revit User
While going throught the revit house kit the presenter mentioned that the lesson project can be used as a template for future house projects. The problem is that the project was done using imperial format whereby I want it to be metric. Does anyone have a metric pemplate or can I convert the lesson template?
Regards
Jan
When you install the software it gives you the oportunity to install all the metric templates and metric tutorials, the template that you are looking for should be there. When you go to start a new project browse to the template files folder and go up one level if you installed your metric files they should be right there, good luck
Mirror Project - Revit Architecture 2013 |
Sat, Jan 25, 2014 at 5:41:31 AM
project standards |
Wed, Feb 1, 2012 at 11:18:52 AM
Cannot Edit Label After Inserting into Project |
Fri, Sep 14, 2012 at 7:07:14 PM
Having more than one project north within a project? |
Fri, Mar 26, 2010 at 7:05:09 AM
Revit Architecture 2013 - Track time for project or history of project |
Mon, Nov 4, 2013 at 2:09:27 PM
Members: | 2017243 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
