69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> MEP crossover to ABS from AutoCAD
Fri, Aug 11, 2006 at 4:45:44 PM | MEP crossover to ABS from AutoCAD
hawaii
HELP!!! We want to stay on the industry train. We just crossgraded to Revit/Autodesk Building Systems from AutoCAD 2004. Is there AutoCAD within the systems Plus package? I will be getting the software next week. Is there anyone on the MEP side of the fence that has made the transition or is currently in the transition that can provide some valuable experiential wisdom? Aloha
Electrical Designer
Sat, Aug 12, 2006 at 7:47:36 PM | RE: MEP crossover to ABS from AutoCAD
largemarv
yes it comes packacked with both
Sun, Aug 20, 2006 at 5:32:37 PM | RE: MEP crossover to ABS from AutoCAD
skener
Yes, AutoCAD is the base application for ABS. So the AutoCAD funtionality is there. But you will run into issues trying to go from Building Systems to Revit systems.
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:50 AM
Exporting from Revit 2013 to Autocad MEP 2010 while retaining intelligent object
Sat, Dec 7, 2013 at 12:08:39 AM
AutoDesk Buidling Systems - MEP
Thu, Sep 21, 2006 at 4:28:55 PM
Architect using Revit while MEP use AutoCAD in the same office
Thu, Mar 19, 2015 at 1:53:06 PM
Autocad MEP imported into Revit MEP Pros/Cons
Fri, Jul 22, 2011 at 1:08:46 AM
Page generation time: 1.8513
