51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Elevations Line Weights
Thu, Aug 10, 2006 at 1:00:09 PM | Elevations Line Weights
meinarch
I know there have been numerous discussions about this in the past so forgive me if this seems redundant.........when I plot exterior building elevations, they seem very "washed out" - all of the lineweights seem to be exactly the same (like thin lines). I've even had a freind with Revit plot them for me and they seem better leading me to believe that part of the problem may be specific to my settings in Revit or in my plotter (HP DesignJet 330) . Beyond tracing over with linework, are there any settings that I'm missing that could help this problem?
Thu, Aug 10, 2006 at 2:56:35 PM | RE: Elevations Line Weights
freestyle250
Check the setup of your phasing and see if youre current phase is different than the phase the building was drawn on.
Tue, Aug 15, 2006 at 10:02:57 AM | RE: Elevations Line Weights
meinarch
Thanks Free - will try that.
Tue, Aug 15, 2006 at 2:58:01 PM | RE: Elevations Line Weights
Poppy1977
DGCad has some great videos for Revit, ADT, and AutoCAD. Many of them are free! One of the free ones I know talks a bit about elevation line weights. It mentions an easy step to adjust line weights in your elevations. Attached is a link to thier web site. Poppy
Wed, Aug 16, 2006 at 10:41:38 AM | RE: Elevations Line Weights
jfurlong
your printer options will make a difference, when i print with fast draft my elevations look washed out, try playing around with your printer options. if you search the forms you will find some good advice on how to change the lineweights in elevation using the line work tool.
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:08 PM
line weights, elevations, and clipping
Fri, May 11, 2007 at 4:14:07 PM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:39 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:33 PM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:37 PM
Page generation time: 1.1628
