27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
Thu, Aug 10, 2006 at 12:14:37 PM | MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
brianjwh
THE MASSES I'VE CREATED, EVEN THOUGH THEY HAVE TEXTURES AND SURFACE PATTERNS EMBEDDED IN THEM , APPEAR AS THOUGH HTEY WERE CLEAR, HOLLOW OBJECTS WHEN VIEWED IN HIDDEN LINE MODE IN ELEVATIONS AND PERSPECTIVE SHOTS. ANY GOOD IDEAS ON HOW TO REMEDY?
Thu, Aug 10, 2006 at 2:59:03 PM | RE: MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
freestyle250
maybe check and see if you have the element properties set up to be a solid or a void.
Thu, Aug 10, 2006 at 3:30:41 PM | RE: MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
broncos4life
3.5 Stars: 11 Votes
How do they look with shading? The transparency on your material may be set to an extream so they are transparent.
Fri, Aug 11, 2006 at 8:08:55 AM | RE: MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
brianjwh
Element properties (solid/void) are set correctly, material is at zero transparency. the objects look fine in shading w/edges when printed. They are simply small cubes reprsenting frieze molding. any further input would be appreciated. thanks
Fri, Aug 11, 2006 at 8:21:17 AM | RE: MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
broncos4life
3.5 Stars: 11 Votes
Set your transparency at 99 and let me know how it looks.
Fri, Aug 11, 2006 at 9:29:35 AM | RE: MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
lpromana
4 Stars: 2 Votes
masses are transparent objects that will help you create other geometry, to make them "hold" their matterials correctly you need to use the create in place command and make them as part of a whatever family and so they become objects, or you can use the wall to face or roof to face in the massing tab. I hope this answers your question Smile
Fri, Aug 11, 2006 at 1:18:15 PM | RE: MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
Poppy1977
I've had issues with this, too. Mainly when exporting to a DWG with elevations. Creating a family in place makes since. I'll have to try that one when I return from LUNCH! Poppy
printing masses with hidden line removal so they are solid
Fri, Nov 16, 2007 at 2:14:43 PM
Show Hidden Lines - Structural Foundations
Thu, Jan 13, 2011 at 10:37:01 AM
Hidden Line Tool not working through links.
Tue, Jul 20, 2010 at 9:06:08 AM
Please Help: Seeing wireframe pieces in a hidden line elevation [ 1 2 ]
Fri, Jun 17, 2016 at 11:04:14 AM
20
Hidden Lines disappeared from all my Elevations
Fri, Mar 1, 2013 at 12:37:04 PM
Page generation time: 2.6059
