68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> car ramps - visual dilemma....
6 Posts No Rating |
Hi,
I am making a car ramp in a car park, and it works with making a ramp and changing the slope. The thing that bothers me is that the ramps is drawn over its total length in the starting level of the ramp, and the ending level of the ramp. Is there a separator or something that only visualises a part on the ramp on one level, and the rest of the ramp on the other (like you have with stairs)?
i'm pretty sure the 'ramp' function would do this. It's found under the same option as stairs. You'll just need to add a new ramp with properties that support the weight of a car (rather than just people!).
6 Posts No Rating |
Is that a Revit 9 option? We work with Revit 8.1 and I can't seem to be able to get it right...
I just finished a 4 level garage. By setting your cut plane, you will cut the ramps at each level on your plan drawings. You will want to set your top level deep enough though so that you see the entire ramp down to the next level.
Placing objects on ramps |
Fri, Aug 15, 2008 at 9:45:32 AM
Attach Walls to Ramps |
Fri, Feb 18, 2011 at 6:45:16 AM
How do you change car colors (properties)? |
Wed, Mar 9, 2005 at 5:21:53 PM
I need a small Hybrid car model for a rendering |
Wed, Jun 1, 2011 at 8:18:12 AM
Car 3D Model |
Fri, Aug 5, 2016 at 9:30:37 AM
Members: | 2016928 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
