208 Posts No Rating |
Hi all,
Is it possible to make a wall that has been marked as 'Demolished' (you have used the demolished tool on it) transparent in your elevation andsection views?
cadjockey
1 Posts No Rating |
TO MAKE A DEMOLISHED WALL TRANSPERANT GO TO PHASES UNDER SETTINGS, THEN GRAPHIC OVERIDES. THEN GO TO 'MATERIAL' FOR THE DEMOLISHED PHASE AND GIVE IT A COLOUR AND U CAN MODIFY ITS TRANSPERANCY. REGARDS, DVSBOB
it doesnt give transparency in floor view or section view only in perspective views....
SOLUTION-
Go to Manage Tab > Phases > Graphic Overrides tab > change cut patterns to hidden / not visible
Then-
Go to view properties >
Visibility / Graphics > (or view template already applied to view)
Filters >
Create a new filter for walls, name it; Wall Demolished, Under Category tick Walls, Under Filter Rules; Select Phase Demolished, equals & new construction.
Add the new filter to the view / view template
highlight the Walls Demo filter in the list, check enable filter and visibility, CHANGE TRANSPARENCY TO 100%
RESULT in Revit 2022 = the outlines of the walls are shown but the core is now transparent.
I assume this works for previous revit versions too.
