120 Users Online (119 Members):
Forums >> Revit Building >> Technical Support >> Adjusting section lines
35 Posts No Rating |
On a current project we have a section line that occours across two areas of the plan, using the split segment tool. following this we picked on the break line tool which allows us to remove all traces of the section line on the plan except near the head, by draging the blue dots onto each other.
This works on three of the four levels - on the fourth level the only two blue dots that show are the ones at each head, therefore we cannot adjust how the section line looks on this sheet.
Has anyone else encounted this problem and, if so, does anyone know a solution.
Adding gaps to jogged section lines |
Tue, Sep 3, 2013 at 10:08:40 AM
Section Lines not showing up on a plan |
Thu, Jan 8, 2009 at 9:32:28 AM
RAC 2011 is there a way to change all level lines to 2d or 3d at once? |
Mon, Dec 6, 2010 at 7:57:35 PM
Section lines |
Thu, Jan 11, 2007 at 7:23:26 PM
Extra Roof Lines in Section |
Thu, Jan 28, 2016 at 12:45:54 PM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
