Forums >> Revit Building >> Technical Support >> Why can't I make an "accelerator" so that space bar repeats last command?
Autocad has been doing this forever. Instead of having to scroll the mouse up to the top of the page, select the move or dimension command over and over, then scroll back to excecute the command, etc. why can't I just hit space bar and repeat the command without moving the mouse? I have gone to keyboardsshortcut.txt trying to create it and found no way to do it.
Is this one of those basic drafting benefits that the Revit programmers (being too busy looking for more flashy things to do) just overlooked? I remember complaining three years ago about Revit not having the select with "box to the left selects all things crossing and box to the right selects all things within" like Autocad. It suddenly appeared in the next release.
Any suggestions?
Post edited on 2006-08-08 09:48:00
Post edited on 2006-08-08 09:48:24
I've wondered about that...it would be a real time-saver if Revit had something like this!
JOHN
John Acosta ARA, Architect Mountain Architecture, Big Bear Lake CA |
Right now th Spacebar will Rotate or flip oientation of walls/components while placing them. Not sure what it would take to retask the spacebar. Maybe someday they will swap the keyboardshortcuts.txt file for a hotkeys dialog box under settings.
17 Posts No Rating |
ditto on alla that... it's nice that spacebar flips stuff around, but the enter button could easily be a 'repeat last command' hotkey, non? I eelee* miss that feature of CAD. Never thought I'd catch myself saying something like that!
31 Posts No Rating |
I have a related problem. I just joined a team with a big Revit project well underway, but their spacebar doesn't flip rotate. Does anyone have insight as to what's going on?
Got no response on TechForum so I will ask here. Why can't you have an......... |
Mon, Aug 21, 2006 at 6:22:41 PM
Large Monitors and Options Bar "Skipping" |
Thu, Apr 23, 2009 at 3:22:07 AM
"stretch" command????? |
Wed, Apr 5, 2017 at 3:38:59 PM
Why some 2 letter shortcuts require enter or space bar and others don't |
Tue, Dec 31, 2013 at 10:39:20 AM
"Squiggled lines" in Revit |
Tue, Jul 14, 2009 at 11:42:44 AM
Members: | 2100144 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
