77 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> Revit vs construction management
Quote from http://www.aecbytes.com/buildingthefuture/2006/BIM_Awards.html
"Graphisoft Estimator was used for the customization of cost and scheduling data, while Graphisoft Constructor was used to generate a fully-coordinated construction schedule by directly referencing portions of the architectural model and linking them to construction activities."
Do revit have any built-in or API similar to Graphisoft Constructor?
----------------------------------- Life is never easy but nor it should be complex. Just stay simple |
6 Posts No Rating |
If you link Revit with Navis Works, Navis works has the ability to do this with is Timelinker program
also Autodesk has aquired Navis Works, so i'm sure in the future these two-programs will work hand-in-hand.
Does Revit support Facility Management? |
Mon, Dec 4, 2006 at 10:18:50 PM
Traffic management |
Thu, Apr 7, 2011 at 5:54:01 PM
Revit 2013 Model Review Management File |
Fri, Mar 22, 2013 at 12:20:14 PM
best practice for construction notes in Revit |
Mon, Mar 16, 2015 at 2:32:24 PM
Sheet and File Management Questions |
Thu, May 28, 2009 at 10:34:10 AM
Members: | 2057574 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
