99 Users Online (98 Members):
Forums >> Revit Building >> Technical Support >> New Regulation isues
17 Posts No Rating |
Hi
i am the building cad designer for reed construction and i need to find out how to chang the way that the flanking walls join the party wall on a terrice block of houses.
As you all will know we have to follow the Robust detail plan for Block and wet plaster or face a big payout to a sound enginer for testing.
How can i acomplish this in revit
In the wall setup you can set each layer of the wall to different priorities. Priorities of the same level will trim together. Ie: Finish (4) or Finish (5) or Structure (1) or Substrate (2) or Thermal/Air Layer (3). A 4 layer and another 4 layer will trim to each other. If you have a wall with a 1 layer and another with a 1 layer and a 5 finish layer, the 1's will join to each other and the 5 inbetween will be cut out.
I hope i made some sense anyways.
Thanks for your help Mr Spot Uk Building regulations are going mad
Changing wall finishing thickness without having to align it again |
Tue, Jul 3, 2018 at 10:42:11 AM
Revit 2014 Update 2 crashes constantly on Nvidia Quadro FX 3800 cards |
Tue, Jun 17, 2014 at 10:26:06 AM
Research project on the UK construction industry and BIM |
Sun, Apr 21, 2013 at 10:38:56 PM
using views in other revit projects |
Thu, Nov 11, 2010 at 8:22:00 AM
Managing multiple copies of a building section in the same project |
Thu, Oct 24, 2013 at 2:58:56 AM
Members: | 2017021 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
