Forums >> Revit Building >> Technical Support >> REVIT 9 INTSTALLATION ISSUES
i just downloaded revit 9 and when i get to the install screen where it says Revit Building 9 Install is preforming the reqested operations, i get an error message
Error 1723 there has been a problem with this windows installer package. A DLL reqired for this install could not be run.
any idea on what this means ? i downloaded it right from the revit main site.
this is the answer from the Autodesk website, support link when you type the number of your error:
Error 1723. A DLL required for this install to complete cannot be found
Solution
This issue is most often caused by out-of-date operating system software. You should make sure that you have installed all of the Microsoft Windows updates and service packs for your operating system. You should also make sure that you are using a fully updated version of Microsoft Internet Explorer 6 as your default web browser.
good luck
oh ok that helps can you privide the links for xp service packs updates?
If you need service pack 2 rather try and find the disk that you can get. Getting service pack 2 from the website makes you download a virus in the background. Then simply update your windows with normal methods. It should be fixed then.
so u mean i would have to out and buy the disk?
try just clicking on the start button and select windows update and it will take you to the update site and check your computer for updates. you should set your computer up to check for updates on a regular basis.
HTH
Post edited on 2006-08-04 10:16:25
ill try it , i owuld ve hads it set up but ive got dialup so it would take forever to update
12 Posts No Rating |
I had a similar problem, but my dll issue arose when I tried to access my help files and tutorials. A Microsoft update last fall disallowed remote accessing of dll files. This is the solution they gave me:
Click Start, click Run, copy the following command to the open box and click OK after each roll. You are expected to receive a successful conformation after running each command:
regsvr32 /u "C:windowssystem32itss.dll”
regsvr32 /u "C:windowssystem32itircl.dll"
regsvr32 /u "C:windowssystem32hhctrl.ocx"
regsvr32 "C:windowssystem32itss.dll"
regsvr32 "C:windowssystem32itircl.dll"
regsvr32 "C:windowssystem32hhctrl.ocx"
Please restart the computer and check the issue.
Good luck!
Having issues uploading to Revit City |
Mon, Jun 29, 2015 at 12:22:13 PM
Issues Upgrading Revit File |
Fri, Jul 12, 2019 at 4:26:07 AM
Mirror issues, mouse selection issues |
Wed, Dec 10, 2014 at 4:14:29 PM
CL Symbol Issues |
Sun, Jun 19, 2011 at 11:17:44 AM
Rendering Issues!!! |
Mon, Sep 29, 2014 at 8:52:20 AM
Members: | 2098617 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
