63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> phasing
2 Posts No Rating |
On the floor plan, I would like the existing walls to display w/ a
lighter line work and the new construction to display normal. The
problem I am running into is that when I use graphic override for the
existing phase, and I change the line color, I am required to assign a
line type.. But I do not want to. I would like the existing lines to
remain 'by category' and just be grayed out. Example: If I were to
pick solid as the graphic override line pattern (which is the
default?) the existing stairs all become solid line work (as opposed
to the overhead part being dashed).
Any suggestions?
Thanks
Phasing - Building Already Done but Dind't Set up Phasing |
Tue, Dec 15, 2009 at 7:40:42 AM
phasing |
Tue, Oct 23, 2012 at 8:20:21 AM
Phasing moved to Visibilty/Graphic |
Wed, Nov 18, 2009 at 4:11:56 PM
Wall and Instance phasing warning - Incorrectly Reporting? |
Thu, Oct 11, 2018 at 3:37:00 PM
PHASING |
Tue, May 20, 2008 at 1:57:25 PM
Members: | 2068289 | Objects: | 23091 | Forum Posts: | 152297 | Job Listings: | 3 |
