116 Users Online (115 Members):
Forums >> Revit Building >> Technical Support >> Pattern Creation Tutorial
29 Posts No Rating |
Hey all,
I've done an exhaustive search online for a tutorial on how to create hatch patterns and have hit a wall. Does anybody know of any way to create hatch patterns quickly and easily? I've found the revit.pat file and good grief it makes creating hatch patterns as a very difficult drawn out process. =
----------------------------------- RHL Design Group Inc. |
any of the pattern creation tools used to create autocad pattens should work fine
HTH
Post edited on 2006-08-02 15:15:07
If you have AutoCAD, open the ACAD.pat file with notepad. You will see tat all of the various hatch patterns are titled. Using that as a division, find and copy the AR-B816 block pattern.
These patterns are basically written as pen up, pen down angles and distance - not in that order but you wont need to know for this.
I don't remember which is which but I believe you should replace the 2nd #8 & th 4th #8 with a #4. That should give you a 4x16 block pattern. Rename the pattern heading and save it as a name.pat file then load it in.
Thanks for the replies guys. I'll try those out. I was just hoping there was another way besides the text file. I've just recently found out that there is a function in autocad that allows you to create line types. Perhaps the function to make hatch patterns in a similar manner has yet to be made.
Thanks again.
Kune
1 Posts No Rating |
you can create custom patterns with a software called "HatchKit". i downloaded it yesterday from the site http://hatchkit.cadro-pty-ltd.qarchive.org/ i havent' had the time to create any custom patterns, but it seems to be more user friendly than notepad....
mass, edge creation r2011 |
Fri, Oct 29, 2010 at 6:37:04 PM
Free REVIT Family Creation Video Tutorial Series at Revitcity |
Sat, Oct 4, 2008 at 11:16:32 AM
Free Family Creation Video Tutorial Series at Revitcity |
Sat, Oct 4, 2008 at 11:13:31 AM
Multiple Configuration Families Creation? |
Tue, Aug 19, 2014 at 12:54:51 PM
Creation of a new Material Surface Pattern |
Wed, Sep 21, 2011 at 6:43:53 PM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
