Forums >> Revit Building >> Technical Support >> Split Face Masonry Block
29 Posts No Rating |
Hey all,
I'm looking for either a hatch pattern for split face block or a tutorial of sorts showing me how to create new hatch patterns. I'm currently working on a project where the design intent is to have split face block up to one height and precision block above that.
Any help I can get would be greatly appreciated.
Thanks
Kune
----------------------------------- RHL Design Group Inc. |
Has anybody created a wall family that has a 'rough' face to it, ala split face block?
There are plenty of sites on the web explaining how to write a pat file. Personally i prefer to just draw the hatch pattern as a DXF then using Hatchkit to convert this to a pat file.
As for the split faced block, you can't give your wall a rough look as such. You'll just need to set the wall up to have a thickness that allows for the width of the splitfaced variations... It would be nice, but i could imagine it killing performance if it was implemented.
Thanks Mr. Spot. Your probably right about the rough face killing the performance. It'd be nice to have though. I ended up working it out by creating a new wall type with the split face accurender but instead of the natural 7.625"w I made it 9"w. Just enough, I think, to make it pop. I could probably get away with 8.5" come to think of it.
Thanks again,
Kune
Post edited on 2006-08-03 18:27:03
Split face conc masonry section |
Tue, Jun 7, 2011 at 11:07:52 AM
SPLIT FACE BLOCK |
Tue, Jul 18, 2006 at 10:41:25 AM
Rendering Split face block in RAC2009 |
Mon, Jan 12, 2009 at 10:55:21 AM
Split face for multi colored wall |
Wed, Oct 7, 2020 at 3:18:12 PM
Split face on floor? |
Wed, Nov 18, 2015 at 1:16:29 PM
Members: | 2100330 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
