67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> .SHP File
Tue, Sep 28, 2004 at 4:11:05 PM | .SHP File
SteveB
3.5 Stars: 5 Votes
I was given a site survey from and aerial GIS service. Is there any way to import this into revit?
Tue, Sep 28, 2004 at 5:25:33 PM | RE: .SHP File
hjacobs
admin
hjacobs Avatar
3.5 Stars: 17 Votes
can you import it to autocad? If you can, then save to dwg and then import to Revit. Post edited on 2004-09-28 17:31:33
Hiroshi Jacobs
Wed, Sep 29, 2004 at 7:03:28 AM | RE: .SHP File
SteveB
3.5 Stars: 5 Votes
No, I cant find any way in the help files to import it. I am told it is possible in Autocad MAP. Any one know of a way to import .shp files into REVIT or AutoCad?
Mon, Oct 4, 2004 at 5:41:38 PM | RE: .SHP File
Osir
We use a 3rd party converter. There are several on the market, we use "Arcv2CAD 3.2" Shapefile to DXF/DWG Converter. Several of the products will allow you to use them a few times before purchasing, if you just need it for one-time use.
Tue, Oct 5, 2004 at 6:52:15 AM | RE: .SHP File
SteveB
3.5 Stars: 5 Votes
yes, I found Arcv2CAD at http://www.guthcad.com/arcv2cad.htm Worked well. Each shape file was a separate layer which is separately converted to a dxf file. I converted these in autocad. You can import dxf direclty to revit also. I don't know how many areas have it, but this particular county had a nicely organized GIS department with topo, property, soils, hydrology, floodplain maps all in the .shp file, available for a small fee, great for prelim. land planning. Steve Brown
Text editing turns TT font to a series of boxes, letters not shown.
Tue, Feb 5, 2013 at 11:52:11 AM
Shared Parameter File Deleted
Mon, May 19, 2014 at 11:30:31 AM
how to convert a template to project file in 2012
Fri, Aug 2, 2013 at 2:58:22 AM
Model file vs. Sheet file
Sun, Nov 9, 2014 at 4:54:45 PM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:16 PM
Page generation time: 0.6405
