56 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> CREATING A TOPOSURFACE EASILY
Wed, Aug 2, 2006 at 9:07:34 AM | CREATING A TOPOSURFACE EASILY
moxierawk
IMPORT YOUR SITE PLAN IN AUTOCAD AND DRAW IT OUT AS YOU WOULD NORMALLY. tHEN GIVE EACH CONTOUR THE SPECIFIED Z HEIGHT IN 3D. YOU SHOULD HAVE YOU A STEPPED LINE LOOKING KIND OF LAND IN ACAD 3D. THEY SHOULD ALL BE CLOSED ALSO. THEN SAVE IT AS A DWG. IMPORT IT INTO REVIT. IT WILL BE FLAT. THEN GO TO TOPOSURFACE AND CLICK IMPORTED INSTANCES. fINISH SKETCH AND YOU SHOULD HAVE A NICE TOPOSURFACES WITHOUT USING THE POINTS SYSTEM OF REVIT.
Thu, Aug 17, 2006 at 6:21:12 PM | RE: CREATING A TOPOSURFACE EASILY
CJCoon
Thanks Moxie....I'll try that out tonight.
RHL Design Group Inc.
Sun, Aug 27, 2006 at 3:03:53 AM | RE: CREATING A TOPOSURFACE EASILY
pacoleonce
If your surveyor topographic drawing has points with x,yand z coordinates, try this: On the web,find a lisp function called ascpoint.lsp, run this function in Acad (Appload, then follow instructions) This will provide you a CSV list (coma separated value) import the list in Revit Magic!! pacoleonce (France)
Toposurface and ACAD files
Tue, Nov 2, 2004 at 4:26:49 PM
A toposurface problem?
Mon, Sep 18, 2006 at 9:16:10 AM
toposurface
Tue, Dec 6, 2005 at 3:49:57 PM
Toposurface Outline
Mon, Jul 8, 2013 at 1:02:11 AM
Adding a subregion to a second toposurface
Thu, Apr 18, 2013 at 3:01:18 PM
Page generation time: 0.4506
