Forums >> Revit Building >> Technical Support >> HOW TO OPEN DOORS DURING A WALK THROUGH
21 Posts No Rating |
DOES ANYONE KNOW OF A WAY TO OPEN THE DOORS WHEN YOU ARE WALKING THROUGH THE RENDERING, EITHER THAT OR YOU JUST BARREL ON THROUGH THEM. I KNOW HOW TO DO IT IN OTHER PROGRAMS BUT WE CAN'T NAIL IT DOWN OVER HERE.
2 Posts No Rating |
In my training I was told that that features on the wishlist for the next edition. Crappy, I know.
Actually you can do it in Revit 9, you just have to edit the door family so that it is open. So you should be able to do the same for previous versions.
Revit does not support "animation" and as such the doors cannot "swing" open during a walktrough.
You could however find or develop a door family where the 3D geometry of the door is in an open position. This would at least allow a more realistic walkthrough.
The ultimate of course is to save the 3D .dwg file out of Revit and link into 3D Studio Max and do the animation during the walkthrough in Max.
HTH
Tom
THANKS. WE DO USE ALITTLE STUDIO MAX SO WE'LL JUST EXPORT IT THERE. tHING IS THOUGH WE WERE MOSTLY AN AUTOCAD FIRM WITH NO 3D OR MODELS. REVIT IS JUST SO MUCH DIFFERENT THEN WHAT WE ARE USE TO. lEARNIGN ON THE RUN.
Most of the doors in our porjects have vision panels in them. As a result of this we adjust the path of the walk through and have it pass through the vision panel. It also keeps the doors closed in the elevations in the actual CD/DD set.
Rendered Walk through |
Mon, Nov 22, 2010 at 4:58:08 PM
Walk thru |
Wed, Apr 29, 2009 at 9:41:47 AM
how to open family-doors in 3D? |
Fri, Sep 22, 2006 at 1:12:30 AM
Walk Through |
Thu, Feb 18, 2010 at 2:35:39 PM
Can I create a walk around? |
Sat, Mar 17, 2012 at 1:29:46 AM
Members: | 2118787 | Objects: | 23205 | Forum Posts: | 152309 | Job Listings: | 3 |
