144 Users Online (144 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Saving a Level Template or Group??
Tue, Aug 1, 2006 at 1:38:52 PM | Saving a Level Template or Group??
ICON
5 Stars: 3 Votes
I have several clients that work off of a different level structure. For instance, one uses a Three foot concrete wall on a thickened slab i-joist flr syst. 108" studs i-joist flr syst. 92-5/8" studs one uses 8' poured walls, 2x10 floor system, 92-5/8" flr syst. 2x10 flr, & 92-5/8" studs. etc. Can I save levels as a group to pull in at the start of a project, depending on which client I'm working for at the time? Thanks in advance. Randy
Tue, Aug 1, 2006 at 2:08:28 PM | RE: Saving a Level Template or Group??
Do them as project templates.
Tue, Aug 1, 2006 at 2:10:20 PM | RE: Saving a Level Template or Group??
TomDorner
4.5 Stars: 25 Votes
I would use different templates for each client. The easist way is to save your last project for each client as the template. I would go so far as to make sure some basic geometry remained in the template so I was off and running the minute I started a project for that client. HTH Tom
Tue, Aug 1, 2006 at 5:50:57 PM | RE: Saving a Level Template or Group??
ICON
5 Stars: 3 Votes
Thanks, I'm still in the process of developing my main template. My concern is that as my main template matures I'll have additional templates to update to stay current with my main template. Is there an easy way to update multiple templates with the same information all at once??
Tue, Aug 1, 2006 at 9:19:48 PM | RE: Saving a Level Template or Group??
TomDorner
4.5 Stars: 25 Votes
Transfer Standards is one of your best friends in Revit. Open up two or more files and then you can "file>transfer standards" from a master file to the others. Tom
Tue, Aug 1, 2006 at 9:28:00 PM | RE: Saving a Level Template or Group??
ICON
5 Stars: 3 Votes
Thanks, gives me a reason to start looking at the "nuts and bolts" part of Revit.
Can't copy furniture group to different level view
Thu, Jun 7, 2018 at 10:43:54 AM
Saving Groups in Revit 2013
Thu, Sep 27, 2012 at 3:13:12 PM
template (.rte) or project (.rvt) files
Mon, Mar 20, 2006 at 3:16:44 PM
Greyed out level and height options on family / group
Wed, Jan 6, 2016 at 1:06:24 PM
Template and save groep
Wed, Jun 30, 2010 at 7:24:56 AM
Page generation time: 8.8819
