43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> plumbing
Tue, Aug 1, 2006 at 5:05:05 AM | plumbing
riazadam
how would i indicate a plumbing route on a drawing
Tue, Aug 1, 2006 at 6:47:52 AM | RE: plumbing
3.5 Stars: 400 Votes
Is this just a 2d indication on a plan? -If so, just a detail lines in drafting mode to your plans.
Tue, Aug 1, 2006 at 7:42:24 AM | RE: plumbing
riazadam
no it a 3d plan
Tue, Aug 1, 2006 at 10:52:22 AM | RE: plumbing
broncos4life
3.5 Stars: 11 Votes
You can buy Revit Systems and do it that way...the way I am going to do it to show roof drains going through the walls with out spending the money for Systems I am going to just extrude a pipe. You could also do a pipe system as a solid by sweep if you have a lot of curves in your pipes.
Plumbing Fixtuer Tags
Wed, Feb 4, 2015 at 1:41:00 PM
plumbing code
Tue, Jun 12, 2012 at 2:18:31 AM
Plumbing systems keep blowing up
Mon, Jul 13, 2009 at 1:04:58 PM
Calculating Total Plumbing Fixtures needed
Mon, Feb 3, 2014 at 9:39:13 AM
Plumbing Risers connecting to mains
Mon, Feb 7, 2011 at 1:53:19 PM
Page generation time: 15.3228
