145 Users Online (144 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Roofing Problems
Mon, Jul 31, 2006 at 3:59:36 AM | Roofing Problems
iqlayser
4 Stars: 1 Votes
Hi. Does anyone know why my roof cuts at on of the sides(u have to look at the attached file) and not on the other side (it cuts on the side with the colums). Thanks
Golf anyone?????
Tue, Aug 1, 2006 at 9:50:30 PM | RE: Roofing Problems
goum
I assume you mean that you're not wanting the roof to be cut?? If so, I would double check that your roof overhang lines are offset from the correct pitching / support point. If they're set out from different points this can cause the roof to be cut this way. Try setting out the overhang from the beam supported by the columns, (if you havn't already done so).
GN Brisbane, Q Australia
Wed, Aug 2, 2006 at 4:19:31 AM | RE: Roofing Problems
iqlayser
4 Stars: 1 Votes
Thanks... yes i did mean i dont want it to cut Keep it up
Golf anyone?????
Roofing Material Look alike
Wed, Nov 21, 2012 at 5:35:57 PM
sloping roofing
Wed, Mar 9, 2005 at 1:21:52 PM
Revit Roofing
Tue, Mar 23, 2010 at 2:30:31 PM
Altering roofing structure in section views R2012
Thu, Jul 19, 2012 at 7:32:50 AM
Tile Roofing
Wed, May 31, 2006 at 8:06:23 AM
Page generation time: 12.0058
