Forums >> Revit Building >> Technical Support >> column surface area
18 Posts No Rating |
Hi'
Pls let me know how to calculate surface area of the column ,also it should come in schedule.
0 Posts No Rating |
Did you get the answer.
I also have same problem,
if you have solution please share
Assuming that you mean that a column is round, and it's not a orthogonal pillar. If you know the height and the radius you have the surface. :-)
surface=2*3.14159265 * r * h
r=radius
h=height
Edited on: Mon, May 15, 2017 at 2:34:38 PM
Edited on: Mon, May 15, 2017 at 2:37:47 PM
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
0 Posts No Rating |
Lol.
Anyhow I got answer from another user.
the question was , how to find area of a curved or irregular surface in Revit.
0 Posts No Rating |
https://www.revitcity.com/forums.php?action=viewthread&thread_id=18008
area plans again? |
Wed, Sep 14, 2011 at 9:07:33 AM
images are showing area surface patterns through them |
Tue, Dec 10, 2013 at 3:40:41 PM
surface patter visibility in plan vs elevation |
Mon, Sep 2, 2013 at 2:05:07 PM
Wall Area Schedule |
Mon, Sep 19, 2011 at 3:44:22 PM
Best way of creating column casings |
Fri, Aug 19, 2011 at 2:17:12 AM
Members: | 2104018 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
