114 Users Online (113 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Different wall colours in plan
Sun, Jul 30, 2006 at 8:11:28 PM | Different wall colours in plan
fabbitecture
I noticed in my plans recently that i have 3 different shading colours, some even with the same properties. Some walls are white infills, some are grey, some are concrete. Even within the same object properties, the cut section of the walls are in different colours. I would like to control it to make it consistent. Help!
Tue, Aug 1, 2006 at 9:56:53 PM | RE: Different wall colours in plan
goum
This may be a silly question. Are the walls at different heights? If the clip plane in the view properties is set above some of the walls, it will make those walls appear to have different fills.
GN Brisbane, Q Australia
Tue, Aug 1, 2006 at 10:46:38 PM | RE: Different wall colours in plan
fabbitecture
I think i kind of solved it. its really weird because sometimes when you join walls to columns and they have different properties, the hatching would eventually turn to a wall hatching. i couldnt figure it out to make the column have a concrete hatching and the wall as blockwork and at the same time they are joined. so what i did was created another file with the columns ahd linked it to the original file so it wouldnt change hatching. Plus, the consistency of the hatchig is also controlled by the detail level.
Different Wall Colours in separate views.
Thu, Nov 15, 2007 at 11:17:41 AM
RAL colours
Fri, Sep 11, 2015 at 3:32:21 AM
Colours
Sun, Feb 14, 2010 at 7:40:31 AM
Car Colours
Wed, Nov 15, 2006 at 3:44:38 AM
Phases
Fri, Jul 12, 2013 at 9:01:42 PM
Page generation time: 1.3073
