117 Users Online (115 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Editing Solid Extrusions
Sun, Jul 30, 2006 at 2:32:50 PM | Editing Solid Extrusions
JTG76
I'm trying to figure out if it is possible to create a solid geometrical shape that doesn't just go up and down like a standard "solid extrusion." I'd like to be able to create solid geometry that can be edited in elevation as well, just like editing the profile of a wall. A good example would be this: I'd like to make some diagonal exterior wood trim for the exterior elevations of a small house. I can create a solid extrusion but that just gives me a vertical object. I'd like to look at it in elevation and edit it that way, but Revit prompts me to open a plan view to edit the extrusion. Maybe there is a better way to do something so simple. Any help on this would be greatly appreciated. Thanks a bunch! -Jason
Sun, Jul 30, 2006 at 9:00:53 PM | RE: Editing Solid Extrusions
hisdirt
5 Stars: 5 Votes
Hey JT, Im not too sure exactly what youre meaning, but you can make extrusions so their profile is drawin in elevation by manipulating the work plane of the extrusion to a vertical plane rather than a horizontal one (default planes tend to be horizontal). Else if it needs to be a little more complex, you could pair the extrusion drawn in plan with a void extrusion drawn in elevation - but voids tend to be best used only when there is no other way.
Creating Solid and Void Extrusions
Thu, Jun 1, 2006 at 10:08:09 AM
Scale extrusions, solid, components
Sun, Oct 14, 2018 at 9:10:51 AM
editing custom extrusions
Thu, Feb 2, 2006 at 4:06:15 PM
Joining extrusions
Tue, Jul 26, 2022 at 3:58:09 PM
Solid Revolve
Thu, Jan 13, 2005 at 10:28:59 AM
Page generation time: 0.3480
