70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> locking the walls in other levels
Fri, Jul 28, 2006 at 4:27:43 PM | locking the walls in other levels
k1PE
i am trying to draw wall in my second level as you know in structural drawing wall shown below the level when i am at level 3 i change my view range so i can see wall at level 2 how can i lock thoes walls and visibilty level i could find anything in the property, thanks
Fri, Jul 28, 2006 at 7:29:09 PM | RE: locking the walls in other levels
coreed
coreed Avatar
4 Stars: 16 Votes
the only way that i know how to lock items in place is to PIN them select the walls you want lock and select the blue push-pin icon fron the EDIT toolbar or goto the EDIT pull-down menu and select Pin Position HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Aug 2, 2006 at 7:22:29 AM | RE: locking the walls in other levels
jstewart
Do you physically want to lock the walls in place or lock them to each other so they will move together? If you want them to move together than use align and a lock will apear so you can lock the walls. I draw a temporary section mark and run it around the building aligning and locking the differnet level walls. Then if I move a level 1 wall I know the upper level wall will move with it.
Mon, Aug 7, 2006 at 6:06:11 PM | RE: locking the walls in other levels
k1PE
Let me rephrase my question I am trying to use wall below as reference for my second floor wall layout. What is the best way to do that? (Revit Structure)
Mon, Aug 7, 2006 at 6:32:19 PM | RE: locking the walls in other levels
CJCoon
You can acutally pick the first floor wall when you create your wall on the second floor. In the view properties look at the underlay. Change it from None to 1st Floor. When you create your new wall on the second floor you can "pick" the wall on the first floor. Check your base offset and overall height to make sure they are what you want. A tip. When you "pick" the first floor wall. The line that looks like a reference plane denotes which side of the wall will be considered the exterior. Hope that helps. Kune
RHL Design Group Inc.
walls look different on different levels
Thu, Mar 11, 2010 at 2:38:20 PM
walls on different levels not even
Tue, Sep 9, 2008 at 2:14:46 AM
VG Filtering Walls by Different Base Contraints
Wed, Apr 1, 2015 at 10:22:29 AM
Join walls command for a group. Issue
Sun, May 13, 2018 at 11:06:03 PM
Placing Electrical on Walls of different levels that are in same view
Thu, Mar 5, 2015 at 9:41:26 AM
Page generation time: 0.6677
