23 Users Online (21 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> placing parking stripes on graded toposurface
Fri, Jul 28, 2006 at 9:56:19 AM | placing parking stripes on graded toposurface
moxierawk
For some reason when I place the parking stripes they do not lie flat on the asphalt subregion I created. The toposurface does have decent grade also. If there is a way respond. Thanks, Brian. Edward Rowse Architects.
Thu, Aug 3, 2006 at 9:06:55 AM | RE: placing parking stripes on graded toposurface
Terry
After aplying parking strip select it, then on toolbar pick (pick host) select the toposurface, it will automaticly aply to it. Post edited on 2006-08-03 09:50:10
Wed, May 9, 2007 at 2:16:43 PM | placing parking stripes on graded toposurface
wagggie
I just went to do this today and you can surely host to the topo surface, but the element is still flat- it does not attach to the slope.  What gives???
Any help here?
Jason
Oculus Inc.
Wed, May 9, 2007 at 2:39:53 PM | placing parking stripes on graded toposurface
wagggie
Okay- just created a parking stripe that works on a slope.  if someone who is better at this could modify and repost it would be appreciated.  this is just a workaround for right now.  BTW- dont set the slope to 0.  you will never get it back.
Jason
 Oculus Inc.
Wed, May 9, 2007 at 9:29:20 PM | placing parking stripes on graded toposurface
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When using pick host the element then sets itself to a flat plane that closest matches the surface.  As the surface probably isn't completely flat its not going to be perfect.
If the main issue is for rendering purposes, what i've done in the past is drawn the parking stripes as sub-regions so they follow the topography perfectly.  Remember this is really only a resolution for rendering as sub-regions can't be tagged or dimensioned to.
 HTH.
Regards,
Chris.
Thu, May 10, 2007 at 7:44:35 AM | placing parking stripes on graded toposurface
wagggie
wow- I never even thought about doing it that way.  Great idea!  I understand about the snapping and such, too bad you cannot dimension to topo edges- I guess its like handrails in section.  Those would be nice to dimension to also.
thanks for the info,
Jason
Oculus Inc.
Putting parking stripes on a slope
Mon, Aug 10, 2015 at 5:10:40 PM
Parking Stripes
Sat, Jul 1, 2006 at 12:18:51 AM
Copy, paste aligned, to level... for parking stripes
Wed, Nov 11, 2009 at 7:32:48 PM
Surface Hatch Pattern on Topography/Subregions
Fri, Oct 24, 2008 at 11:30:57 AM
Topography - Cut and Fill for Graded Region
Fri, Feb 4, 2011 at 11:31:16 AM
Page generation time: 0.2771
