Forums >> Revit Building >> Technical Support >> Revit for landscape and site design
22 Posts No Rating |
How does Revit work for landscape and site design? I am using Revit for architectural drawings, but what is the recommended way to do site planning or colloborate with the landscape architect?
Thank you.
8 Posts No Rating |
I have found that site stuff is a bit tricky in Revit.
It would be ideal to have the Landscape Architect working in Revit.
He or she could then work on a workset that contained the site stuff while you worked on the workset that contains the building. You could then reload to see each other's changes and coordinate almost seamlessly.
If you are mainly focused on construction documents, you could link a landscape consultants cad drawing to your file.
this is the site http://www.eaglepoint.com/ LANDCADD™ for Revit® is designed to offer Architects, Landscape Architects or Designers functionality within Autodesk Revit Architecture to quickly and easily lay out site components, as well as produce a landscape design fully integrated into the project. By accessing a wide-range of searchable plants, you are able to customize planting families and then use the LANDCADD tools to locate trees, shrubs, flowers or ground covers into the model. You are also able to layout other landscaping features, such as paths or patios and, not only obtain areas, but also a takeoff of the materials.
Not Sure What Revit Can Do?... Find it OUT!!!
“Imagination is more important than knowledge...” -Albert Einstein |
Carrucha, this thread has 4 years old man...
better late than never,
Ok, Ok, good point...
hahahahaha Sorry didnt see the date
Landscape Architecture and Revit - The future of |
Fri, May 28, 2010 at 8:19:54 PM
invisible road carparks and landscape on site plan |
Fri, Aug 28, 2009 at 6:44:34 AM
Issues with Linked View |
Fri, Apr 5, 2013 at 12:53:33 PM
Site/Landscape - Rocks |
Sun, Sep 7, 2008 at 10:38:27 PM
11
Landscape in RAC 2010 |
Mon, Sep 28, 2009 at 9:25:33 AM
Members: | 2097992 | Objects: | 23164 | Forum Posts: | 152289 | Job Listings: | 3 |
