43 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Revisions & Superseding
35 Posts No Rating |
We have just switched from AutoCAD to Revit, and I am trying to get a clearer understanding of how revisions work in revit. Our old System with AutoCAD was to always save a copy of the drawing file each time a sheet was issued (separate files for each sheet), so that at any stage if a client decided to revert back to a previous version of the drawings we could simply open that file.
With revit I have a basic understanding of revisions - That you can keep track of revisions through clouds and the revision schedule. Also I have read about the roll back command. However as far as i can tell the revision tracking does not allow you to revert back to a previous revision and if you use rollback all subsequent work is lost. Also how do you know which backup file you want to revert to.
I don't want to have to save the entire file each time we issue a drawing as revit files are somewhat larger than individual AutoCAD files, but do wish to still retain that flexability and fallback safety
I guess I am interested in hearing what other firms do to work around this problem, and if it is even a problem for others at all
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
I still save an archive copy at each revision point just in case. Hard drives are so cheap these days even a simple USB drive for $100 will work if you don't have room on the server.
You are correct in that rolling back to a prior revision state is not automatic yet in Revit. Even if it was, sometimes you added information along the way you don't want to disapear.
HTH
Tom
My revisions schedule won't go over 10 revisions |
Wed, Oct 14, 2015 at 6:37:09 PM
revisions showing up when they are not supposed to (2019) |
Wed, Jul 17, 2019 at 7:39:37 AM
revisions display issue [ 1 2 ] |
Mon, Sep 15, 2014 at 3:23:27 PM
15
Manage Sheet Issues / Revisions across linked projects |
Thu, Mar 17, 2016 at 3:35:39 PM
Issueing Revisions |
Mon, Aug 10, 2020 at 9:14:01 AM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
