78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Request to edit workset Notification message?
Thu, Jul 27, 2006 at 1:51:06 PM | Request to edit workset Notification message?
james048a
1 Stars: 1 Votes
Is there a setting to turn on to pop up a message when someone is requesting permition to edit a workset? Because having to MANUAL check is not a good thing, because people will forget to check and will go un-answered for hours or days. I am runing Revit 9
Thu, Jul 27, 2006 at 5:11:19 PM | RE: Request to edit workset Notification message?
TomDorner
4.5 Stars: 25 Votes
Not yet...it is on the wishlist. Until then many use an instant messaging of some sort or just yell over the cube wall. Tom
Thu, Jul 27, 2006 at 5:28:52 PM | RE: Request to edit workset Notification message?
eldados
eldados Avatar
4.5 Stars: 8 Votes
the problem is that Revit will have to check the server or all the computers all the time to see if there is a request, now imagine an office with 50 Revit users... way too much load on the network.
Integrator
KarelCAD
Fri, Jul 28, 2006 at 10:28:02 AM | RE:
james048a
1 Stars: 1 Votes
Quoting eldados - 2006-07-27 17:28:52
"the problem is that Revit will have to check the server or all the computers all the time to see if there is a request, now imagine an office with 50 Revit users... way too much load on the network."
I guess your office doesnt use Microsoft Exhange.
Its pretty simple to have revit check to see if there is a request pending on the central file. It would be alot lighter load on the network then your email system would be. Autocad has a notification in it if someone updates a xref and alerts others that have the xref linked of a change.
Tom thanks,
Im going to write to autodesk. But in the mean time im going to look into a inner office messanger program, not a MSN or yahoo.
Wed, Mar 28, 2007 at 7:05:09 PM | eldados
webb
webb Avatar
Quoting eldados from 2006-07-27 17:28:52
"the problem is that Revit will have to check the server or all the computers all the time to see if there is a request, now imagine an office with 50 Revit users... way too much load on the network. "
so it's not to taxing a load for revit to keep track of every object in a 200mb file and if it has been altered by any other user, but having an alert system for permissions would take down a network.
yeah, I'm not really buying that one.
Thu, Mar 29, 2007 at 5:35:09 PM | Request to edit workset Notification message?
james048a
1 Stars: 1 Votes
I guess you didnt read what i was saying. This is about Request notification alert not traking every object in the file. It could be a 2000mb file for all i care, its the alert part that if some is requesting to modify something, The alert is not taxing a load. Revit already gets the notifications, you just have to manual check it. Im saying revit could have it automaticly give the requestee an alert pop up, but it doesnt, you have ether call the person or messange them that they have a request waiting.
Thu, Mar 29, 2007 at 5:49:52 PM | james048a
webb
webb Avatar
Quoting james048a from 2007-03-29 17:35:09
I believe this is what some refer to as the pot calling the kettle black.  I was agreeing with you and was pointing out, along the lines of what you posted, that revit already is performing much more taxing tasks to a network than a simple alert system that could piggyback on the system already in place.  this was contrary to what eldados had posted, which is why I quoted him as opposed to you.
settle down, beavis.
Edited on: Thu, Mar 29, 2007 at 5:56:34 PM
Thu, Mar 29, 2007 at 6:00:03 PM | Request to edit workset Notification message?
james048a
1 Stars: 1 Votes
I apologize WEBB,
I didnt see your queot above. Revitcity queot box looks like the posted message box with grey top. Im doing multi tasking on 4 monitors and didnt catch it.
Thanks for agreeing with me.
Yeah your wright, i mean revit already has the program notification link to the file, its in the program itself that needs the alert pop-up.
Signing off for the day.
grant permit request doesn't pop up
Tue, Aug 1, 2006 at 1:27:31 PM
Requests - for Workset
Wed, Mar 15, 2006 at 4:30:44 PM
Purge Unused - Workset Error Message
Mon, Aug 23, 2010 at 1:32:59 AM
WORKSET SHARING
Fri, Nov 13, 2009 at 7:30:20 AM
Can't Edit Workset Parameter
Thu, Oct 23, 2008 at 11:36:23 AM
Page generation time: 4.5400
