81 Users Online (80 Members):
Forums >> Revit Building >> Technical Support >> Display properties of glass in existing windows?
![3 Stars: 2 Votes](/images/stars_3.gif) |
I have drawn an existing building (to be modified in parts) and would like to know how to change the properties of the window glazing so that it is transparent, as it is in windows inserted while they are in the 'new construction' phase. At the moment they are not transparent, is there any way to change this, and why are they not transparent in the 'existing' phase?
----------------------------------- VND |
2 Posts No Rating |
Hello,
It should not make a difference what stage of construction you are in, in the program. Try to select a window, go into the properties of that window and select the edit/new button and review the materials and finishes parameter. it might say glass, or something elese. you have the ability to go select the word glass and get a drop down window and open the materials window, try changing the material on the name side, or go to the left and find the accurender box and select the down and it will take you in to a different stage of materials. from there you would open the accurender folder and choose the glass folder. from there you have a whole range of glass colors and shades. Try that. and i hope it works for you.
Good Luck.
HIG10
Windows are not transparent |
Mon, Apr 13, 2009 at 7:43:00 PM
Windows and Furred out Walls |
Wed, Oct 14, 2009 at 7:47:11 AM
windows don't display correctly |
Tue, Jul 10, 2007 at 1:03:34 PM
Transparency of glass windows in 3d views |
Wed, Aug 5, 2009 at 10:43:37 AM
Door & Window Schedules - how to schedule existing doors and windows |
Tue, Feb 3, 2009 at 11:11:39 AM
Members: | 2017148 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
