53 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Dimension "entire wall"
I haven't checked every wall, but in my current project I can only dimension to indidual references, not the "entire wall".
Is there sometimes an overriding factor or variable that won't let you dimension the entire wall at once??
Thanks in Advance
8 Posts No Rating |
You can either start a dimension and click one side of the wall and then click the other or you can pick the wall. When you pick the wall the length should be shown. Click on the little ruler under the length and it will make that dimension permanent.
Does that help?
When you click on dimension there will be an option on the top menu bar for individual reference or entire wall with some options
Macca Sunshine Coast QLD Australia |
"Simple" dimension question? |
Fri, Feb 29, 2008 at 9:48:32 AM
"EQ" dimension on either sid eof a fixed dimension [ 1 2 ] |
Sun, Aug 24, 2008 at 12:08:50 PM
15
Adding "Suffix" text to dimension strings in 2009 |
Wed, Jun 4, 2008 at 7:29:28 PM
Dimensioning to a "Point" at wall intersection in 2008 |
Wed, Jan 30, 2008 at 9:41:11 AM
Mirroring entire project- "copy" check box greyed out? |
Sun, Apr 23, 2006 at 6:44:57 PM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
