54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> shortcut key for text
Can I have the shortcut key ( tx ) dial down to include the specific text size.
I'd like to speed up the process of adding text, but using the short cut key only gets me to the text part. I still have to take time to select the specific text size, for instance. Also, I still have to select a leader. I pretty much use the same leader for all my notes. Can I set a default to avoid manually selecting.
Thanks in Advance
Randy
40 Posts No Rating |
Template is the answer create your desired txt and save that as your default template.
repeat command shortcut key?? |
Tue, Aug 19, 2008 at 2:15:12 PM
Looking for quick Key shortcut |
Thu, Jul 2, 2009 at 10:22:19 AM
Shortcut Key to Rotate 3D View |
Wed, Dec 1, 2010 at 4:06:52 PM
Key Notes Across Divisions. |
Thu, Jan 27, 2011 at 10:07:01 AM
Deleting Problems (Revit 2009) |
Mon, Oct 27, 2008 at 9:21:15 AM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
