82 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Dividing a section into equal parts
33 Posts No Rating |
Dear friends
Can you please help me out?
Let's say I have a certain section, let's a wall or just a meaningless line and I want to divide it into 3 or 4 equal parts. Is it possible? If so, How?
![3.5 Stars: 5 Votes](/images/stars_3.5.gif) |
Draw a line perpendicular to it. Then use the array command (shortcut "AR" fill in the "number" box with the quantity of divisions you wish to make. Check last.
![amjhd Avatar](user_avatar/16266.jpg)
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
You can also draw 5 lines.. one on each edge
and 3 in the middle (wherever)
Then just dimension all your lines and hit the 'EQ'
on your dimensions.
HTH
Thank you for your help mates ![Smile](/images/smiles/smile.gif)
how to divide a line or object in equal parts? |
Tue, May 14, 2019 at 5:50:58 AM
12
Dividing an external wall into different parts per floor |
Fri, May 12, 2017 at 3:46:57 PM
dividing lines |
Thu, Jan 15, 2009 at 11:09:19 AM
Dividing a line |
Tue, Sep 4, 2007 at 9:06:00 PM
How to locate the objects in distance of "Half Equal, Equal, Equal, Half Equal"? |
Tue, Jun 28, 2016 at 8:50:43 AM
Members: | 2016941 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
