62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Walls
2 Posts No Rating |
How can I create a wood stud wall with exterior cedar lap siding?
35 Posts No Rating |
Draw a wall using the standard timber stud wall under MODELING - WALLS. Go into the walls PROPERTIES, Select EDIT/NEW, Under CONSTRUCTION - STRUCTURE Select EDIT. Expand the view to show the PREVIEW, under view option select SECTION VIEW. Select SWEEPS, Select LOAD PROFILE and choose a previously drawn section profile of the cedar lap boards. Adjust material, distances offsets, etc. Add more boards to suit.
Alternatively if fine detail sections of the wall are not required simply change the walls external finishes surface pattern to show horrizontal lines spaced as required for siding.
2 Posts No Rating |
Thanks, very useful
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:42 PM
Walls |
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls. |
Sun, Dec 14, 2014 at 4:58:35 PM
Members: | 2076249 | Objects: | 23116 | Forum Posts: | 152267 | Job Listings: | 3 |
