Forums >> Revit Building >> Technical Support >> tags family types
29 Posts No Rating |
I'm just trying to organise a template for my office.... and
attempting to get the system familes to have presentation and documentation styles....
it's mainly the difference in the fonts....
but i don't want it to change the presentation drawing styles... when i move into documentation..... any help....
i hope that made sense...
think i understand . . .
you are after different font sets?
easy, just edit/new duplicate etc and create them. if you keep you presentation views and sheets, and create more views and sheets, then the different fonts can be applied.
and i hope that made sense!
thanks latemore..... but...
I am still having some difficulty with the system family tags....
ie: view name.... section tags... callout tags....
I can create another family for them, with the iso font... but when i change them in the project, it changes all of them, on all sheets....
i think i may need to create a type within those families, with the iso font....
but im not too sure how to do that correctly....
Right, Unfortunately you cannot have a section display differently in one view to another.
Solutions would be to duplicate the sections/callouts and then hide them in all other views and set there tags appropriately
OR use a dumb tag reference for that particular view.
OR live with it, load in the different types and everytime you need to print/export that sheet you temporarily change the view tags then swap them back upon completion...
Either way its going to be sloppy and messy.
HTH.
Family types - conditional statement |
Mon, Apr 18, 2011 at 3:59:51 PM
Purge Command - possible to purge family types accidentally? |
Tue, Aug 20, 2013 at 12:01:09 PM
Family types problem. |
Tue, Apr 21, 2009 at 10:00:21 AM
View tags in legend |
Tue, Feb 16, 2010 at 5:59:27 PM
Embedding tags in family? |
Mon, Jul 9, 2012 at 3:19:34 PM
Members: | 2102255 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
