44 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Holding a wall off of a column line
Wed, Jul 19, 2006 at 1:32:55 PM | Holding a wall off of a column line
boo2u20
I'm setting up the exterior wall types for a new project and I know that they will all be 1'8" from the outside edge to the column lines in plan. I'd like to be able to consistently hold this dimension offset from the column lines. Is there a way I can set this up in the new wall types? I know it's possible AFTER placing the wall by dimensioning the column line to outside of wall and locking it. But I'd like it to be integrated in specific wall type. Thanks!
Wed, Jul 19, 2006 at 2:43:32 PM | RE: Holding a wall off of a column line
3.5 Stars: 395 Votes
Why not just adding some air to your wall type .... non printing & then use the inside face to layout..... of course, then you can't dimension to it. I think the above is a fun answer but why don't you just add some temporary lines or planes and then delete them.
Thu, Jul 20, 2006 at 3:08:57 PM | RE: Holding a wall off of a column line
tyar74
Can't you just type in 1'8" as the offset when creating walls? That at least cuts out the step of dimensioning to the column line but still references it for locking. tyar74
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
curtain wall at column
Tue, Sep 8, 2009 at 12:24:40 PM
Flushed Wall & Column
Thu, Sep 6, 2007 at 11:19:18 AM
Line Work Problem
Tue, Sep 12, 2006 at 1:33:36 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
Page generation time: 1.8342
