32 Users Online (31 Members):
Forums >> Revit Building >> Technical Support >> Raking sweeps
208 Posts No Rating |
Hi all,
Is it possible to create a sweep that follows a spiral? eg. a coping detail ontop of a spiraling wall.
If so how is it done?
cadjockey
Post edited on 2006-07-19 00:01:21
Hi all,
Is it poosible?
cadjockey
I don't that it is possible in the way you want it to be done. You might have to draw it for it to work properly.
If you are are trying to create a wall sweep which follows a 3D curve like a sloping spiraling wall, try creating the sweep in place and instead of drawing the path pick the edge of the wall which it is to follow.
Hope that will help.
LT2014 - Ceiling Based Model Disappears Halfway Across Raking Ceiling |
Wed, Sep 4, 2013 at 7:24:16 AM
Problem connecting wall sweeps (horizontal and vertical) |
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps |
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps |
Fri, Aug 31, 2012 at 3:58:55 AM
Can you rotate wall sweeps? |
Wed, May 2, 2012 at 9:23:44 PM
Members: | 2066361 | Objects: | 23085 | Forum Posts: | 152255 | Job Listings: | 3 |
