28 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Shared Parameters
Sun, Jul 16, 2006 at 9:54:18 PM | Shared Parameters
Rusyel
Has anyone figured out a way of using shared parameters so they can schedule the samd data across multiple categories. For example we would like to ba able to Tagg doors so the door mark and its associated room appear in the same tag. Or we would like to tag an area which shows the ceiling height? Ive been loking into it for a while and cant seem to figure out if REVIT can even do it, is this even possible? Right now we use shared parametrs but need to enter the data seperately into each category. Rod.
Mon, Jul 24, 2006 at 5:57:32 AM | RE: Shared Parameters
Elmo
3.5 Stars: 4 Votes
As long as the shared parameter is used in a family or tag it should register inside a shedule. So in other words assign the shared parameter in your in your tag and your family and it should work in both plus the shedule.
Mon, Jul 24, 2006 at 6:36:19 PM | RE: Shared Parameters
Rusyel
Hi Elmo, I actually need to ba able to schedule data from two categories in the one tag. I would like to be able to use a door tag for example which pulls data from a shared parameter in the door family but also a shared parameter associated with a room. In more detail: I want to be able to load a shared parameter called room number and associate it with the door and room categories, then be able to enter the room number into the room but be able show this data in the door or window tag.
Mon, Jul 24, 2006 at 8:36:47 PM | RE: Shared Parameters
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Rod, As you've discovered this is not possible. Even a multi-category tag can only reference information from a single family at a time. It would be a very nice inclusion however. Add your support on the Augi Wishlist.
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:11 PM
Project Shared Parameters or Shared Parameters in Families
Fri, Feb 21, 2014 at 10:22:42 AM
Creating Shared Parameters
Tue, Nov 25, 2008 at 4:45:08 AM
Shared Parameters File is not a valid...
Wed, Feb 12, 2014 at 9:31:26 AM
Page generation time: 0.4971
