Forums >> Community >> The Studio >> ROOF Corners - TWO different Slopes
Sat, Jul 15, 2006 at 1:15:20 AM | ROOF Corners - TWO different Slopes
boydj
I am trying to connect a small shed roof (10/12) off the side of a house that meets at a corner with a 18.5"/12 roof. Each made from a footprint. Joining/attaching does not work. There has to be a way. The attached image shows what I would like to accomplish and where my model is at. ALSO can you join a roof to a vertical wall AND another roof in the same process? Thanks Boyd
Tue, Jul 18, 2006 at 9:59:14 AM | RE: ROOF Corners - TWO different Slopes
josta
1 Stars: 1 Votes
I would shorten the overhang on the steeper roof to match the photograph, then experiment with the footprint lines for the lower roof until it joins just right. I'm not sure if this is the elegant way to do it, but it sure works for me. JOHN
John Acosta ARA, Architect
Mountain Architecture, Big Bear Lake CA
Tue, Jul 18, 2006 at 10:26:14 AM | RE: ROOF Corners - TWO different Slopes
rkitect
rkitect Avatar
4 Stars: 29 Votes
If you're not a member of AUGI: 1) You'll need to be in order to view this thread. 2)Why aren't you? You do use Revit.. right? =P http://forums.augi.com/showthread.php?t=39078&highlight=gable+return This has a solution that you could possibly use. I don't see any reason for the join tool to not work... except that I've had the same problem before. Redrawing the roof solved the problem =) Post edited on 2006-07-18 10:26:24
sloped flat roof - Q2of2
Mon, Sep 11, 2006 at 5:25:29 PM
revit roof slopes
Tue, May 6, 2014 at 10:19:05 AM
Adding skylights and slopes to a roof
Thu, Jul 12, 2012 at 8:33:07 AM
roof issue (even roof valley slopes with uncentered drain locations)
Wed, Mar 14, 2012 at 12:25:14 PM
Roof Footprint - Fillet corners
Fri, Oct 14, 2011 at 12:17:57 PM
Page generation time: 0.8171
