55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Is there a way to make a complex curving wall in REvit?
9 Posts No Rating |
Is there a way to make a complex curving wall in REvit? For example a 20' radius in plan with the wall having either a conical or curvilnear vertical change simultaneously?
Blended sweeps or lofts are not possible in revit. You can however import a sketch up file or autocad modelled version of what you require into a massing family and use this as a face to create your wall. This retains all the parametric abilities of the wall enabling it to host doors/windows etc...
HTH.
9 Posts No Rating |
Thanks!
This has kept me from doing some of the interior models I have wanted to do.
I will try modeling it in AutoCAD and Importing it!
Problems with Complex Curved Curtain Wall. Help! |
Mon, Nov 14, 2011 at 10:08:54 PM
How do you model a complex curved handrail in Revit 2011? |
Wed, Aug 10, 2011 at 12:23:34 PM
Imported Complex Geometry -->wall by face |
Fri, Sep 7, 2007 at 12:27:38 PM
CURVING AN OBJECT.. HELP ME AGEN.. |
Sun, Feb 22, 2009 at 9:48:40 AM
Help with Complex Massing and Curtain Walls |
Sun, Feb 12, 2012 at 4:51:27 PM
Members: | 2030869 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
