103 Users Online (101 Members):
Forums >> Community >> The Studio >> Please help - Glass Railing
1 Posts No Rating |
hey. i know this is probably really elementary, but i am getting frustrated and still not able to figure out how to make a glass railing. i have glass balusters, but can't figure out how to load them into the railing options and actually use them.
any advice appreciated. thanks!
39 Posts No Rating |
Ok... well. A 'railing' is a profile. So you could duplicate one of the railing families already in revit and modify it or create a new family, starting with the 'profile' template.
If you wanna duplicate an in-project railing, then go railing> properties> edit/new> (choose which one to duplicate) duplicate> 'rail structure'. there should be some profiles in there (top and bottom) and on the right hand side there should be the material option, change that to glass.
If you wanna draw your own profile, do that, and then load it into your project, and in the 'rail structure' option, look in profile and your new one should be in there.
Now for your balusters, if you've made them, and loaded them in, they should be found in your 'baluster placement' option, just under your rail structure. In main pattern, at top of window, change the baluster family to the one youve made. and adjust the distances accordingly.
I hope that helps :D
Glass panel railing help |
Fri, Jan 7, 2011 at 3:23:21 PM
R2020 - Glass Railing |
Fri, Jan 24, 2020 at 10:36:28 AM
railing with glass or solid |
Wed, Apr 30, 2008 at 5:28:23 PM
Glass Railing |
Fri, Jan 18, 2013 at 12:45:10 PM
glass railing |
Mon, Nov 21, 2016 at 9:21:02 PM
Members: | 2030567 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
