81 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Moving locked walls?
Wed, Jul 12, 2006 at 10:42:23 PM | Moving locked walls?
vnd
3 Stars: 2 Votes
I am trying to move a particular wall to a new position, but an opposite and parallel wall also moves with it. Is it because it is locked to it, and how do I move my wall independantly of other walls. I have attached a dwf file showing the situation. Can anyone help with this?
VND
Thu, Jul 13, 2006 at 9:50:40 AM | RE: Moving locked walls?
krmccurdy
Pick the wall you want to move. Choose "Activate Dimensions" and you should she some temporary dimensions with locks on them. Unlock and move. You may have to manually put a dimension from wall to wall to see the lock. And you may have to try locating the witness lines differently. Are you the only one working on this project? Can you just ask others on the project what dimension they locked?
Thu, Jul 13, 2006 at 5:21:22 PM | RE: Moving locked walls?
vnd
3 Stars: 2 Votes
Something I should know by now... hmmm... thanks for that I'll give it a try and see if that's been the problem.
VND
moving walls
Tue, Aug 6, 2013 at 8:54:03 PM
two walls heights locked, I want to unlock
Mon, Sep 1, 2014 at 2:52:35 PM
Parallel walls locked in relation to one another?
Thu, Apr 27, 2006 at 10:53:42 PM
walls moving together
Fri, Mar 23, 2012 at 3:36:35 PM
MOVING AND ALIGNING WALLS
Sat, Mar 10, 2012 at 5:57:39 AM
Page generation time: 2.3496
