111 Users Online (110 Members):
Forums >> Revit Building >> Technical Support >> Sum Total of areas
208 Posts No Rating |
Hi all,
I am easily able to create a schedule listing respective room areas.
How do you create a single row that shows the total of all those areas?
cadjockey
right clik on the schedule
select properties
select "formatting" tag
select the fied "area"
check the box that says "calculate totals"
You can also then use the sorting and grouping to sub total by other fields.
9 Posts No Rating |
I had the same problem. In addition to selecting "calculate totals" in the formatting tab, you have to click "grand totals" in the sorting/grouping tab, then select totals (and/or titles and counts) from the drop down.
Total number of units per floor in schedule without itemizing every instance |
Mon, Jul 27, 2015 at 5:25:58 PM
sum parameter |
Tue, Apr 28, 2009 at 12:20:47 PM
Calculating Total Plumbing Fixtures needed |
Mon, Feb 3, 2014 at 9:39:13 AM
Schedule Total Inaccurate |
Tue, Feb 21, 2012 at 12:42:04 PM
Areas and area schedules in Revit 2013 |
Fri, Mar 18, 2016 at 7:27:55 AM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
