70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> demolition graphics
Wed, Jul 12, 2006 at 2:50:41 PM | demolition graphics
mezdez24
5 Stars: 2 Votes
Is it possible to change the way demo objects (when shaded w/edges) show up as red?
Wed, Jul 12, 2006 at 3:32:13 PM | RE: demolition graphics
archdan
3.5 Stars: 2 Votes
In the Phases window, you can set the graphic overrides for any object which is being demo'ed. In a shaded view it is done with the material selected. Typically the graphic override is setup to go to the "Phase-Demo" material which is transparent red. You can go into the material editor and modify/duplicate this material, and then reassign it on the Graphic Override Tab of the Phases window(Settings > Phases). Of course, if you don't want the demo'ed object to show at all you should chagne the phase filter for the view. Hope that helps.
Calculate Demolition
Fri, May 8, 2015 at 3:56:12 PM
Modelling a demolition project in Revit
Thu, Feb 11, 2016 at 10:08:27 AM
Demolition Lines Scale wrong / not showing with components.
Mon, Oct 22, 2007 at 9:55:10 AM
Setting wall to demolition, infills - how to stop?
Fri, Aug 5, 2016 at 11:24:19 AM
Edit Demolition Profile Tool
Wed, Mar 1, 2006 at 4:43:34 PM
Page generation time: 1.2486
