40 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Occupancy Loads
2 Posts No Rating |
Does anyone happen to know how to add an Occupancy load calculation schedule so that the area calculation in area settings will develop a table for you?
----------------------------------- John. |
I too would like to know this one?
21 Posts No Rating |
I would also like to know... and how to add ventilation (outside air) calcs in conjunction with this.
Bump.
I created a room schedule that included the room area, name and square footage. I then created a shared parameter for Floor Area Per Occupant. I then created a calculated parameter from within the schedule to calculate my occupants. The formula I used was Area / Floor Area Per Occupant + .49. The .49 insures that it will round up instead of down. Look in the formating of the schedule to round to 0 demicals and then you are done. So I wouldn't have to set up the Floor Area Per Occupant every time, I created a schedule key that had the entire list of the IBC. I now just choose what the room is used for and my calcs are done.
18 Posts No Rating |
TWOMETER: I know you posted this a long time ago but by chance will you be able to tell me how you did this? "I created a schedule key that had the entire list of the IBC. I now just choose what the room is used for and my calcs are done. " thanks!
Room Tags and Occupancy Loads |
Wed, May 9, 2012 at 6:46:45 PM
Area Plan - Occupancy type Revit Architecture 9.0 |
Mon, May 4, 2009 at 2:48:54 PM
room tag with occupancy info (2019) |
Thu, Jan 24, 2019 at 1:34:42 PM
Formulas and Schedules |
Thu, Aug 16, 2007 at 8:46:38 AM
Rename Occupancy name |
Wed, Apr 3, 2013 at 7:27:13 AM
Members: | 2022349 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
