73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> floor finishes
Mon, Jul 10, 2006 at 3:53:43 PM | floor finishes
mezdez24
5 Stars: 2 Votes
How do go about having 3 or 4 different floor finishes on an interior floor? I would like to see them graphically in plan/3d view. I need to take a material take off too. Is this possible? Something similar to the attached jpeg. Thanks!
Mon, Jul 10, 2006 at 5:24:18 PM | RE: floor finishes
geoffy
Why don't you try a Split Region on the floor surface then apply a different material to each section, I have to admit I'm not sure about the take-off though. Hope this helps.
AutoCAD & Revit TAFE teacher from regional Australia
Tue, Jul 11, 2006 at 1:11:16 AM | RE: floor finishes
Erik
I build up the drawings (or correcctly: the model) in Revit close to the way we would build it. So, I use a 12cm structural slab which covers most of the floor areas (set at -50) then I add the flooring (usually, in my part of the world, a 5 cm topping). This finishing floor can be any shape you like also as per your sketch. I have several finishes floors included in my template covering various tile sizes, carpet etc. The quantities will also be corect. Erik
Wed, Jul 12, 2006 at 7:41:46 AM | RE:
mezdez24
5 Stars: 2 Votes
Hope this helps.
Yeah, I've tried that, however I will not be able to get materail quantities from that. I'm not sure if you can apply different materials to each split face. I do know that you it seems to be easier to just custom create a wall. Thanks for the response!
Floor Finishes not showing up in Revit 2013
Thu, Dec 25, 2014 at 5:52:37 AM
floor finishes
Thu, Jul 1, 2010 at 7:19:38 AM
Floor Finishes
Mon, Oct 15, 2012 at 10:42:34 AM
How to have seperate floor finishes?
Tue, Apr 12, 2011 at 7:12:39 AM
floor finish limits
Tue, Dec 19, 2006 at 11:59:08 AM
Page generation time: 0.6791
