102 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Saving to 3dsMax?
Mon, Jul 10, 2006 at 1:28:54 PM | Saving to 3dsMax?
derekc
Can someone tell me if it is possible or if there is a way to save a revit file to 3dsMax/opening in 3dsMax? If so how? Thanks!
Mon, Jul 10, 2006 at 3:03:49 PM | RE: Saving to 3dsMax?
lpromana
4 Stars: 2 Votes
No you cannot "save" to 3Dmax but you can save a 3D view as a DWG and then link it in max through the File Link Manager (I don't have max but I have VIZ and it works there) if you only link the file you can go back to revit and continue designing and then reload any changes in Max
Revit to 3dsMax for GPU utilization
Fri, Dec 21, 2012 at 12:12:35 PM
revit file too heavy when importing into 3dsmax
Fri, Sep 11, 2009 at 1:13:54 PM
how to transform my 3d from 3dsmax into technical drawing
Mon, Jan 19, 2009 at 1:32:51 PM
Linking Revit to 3dsmax 9 sp1
Tue, Jun 26, 2007 at 11:05:38 AM
Revit to 3Dsmax vray glass problem
Tue, Jan 21, 2014 at 8:47:01 AM
Page generation time: 0.6084
