Forums >> Revit Building >> Technical Support >> (again, sorry) columns with plaster?
46 Posts No Rating |
what should i do to create plaster around a column?
2 Posts No Rating |
Hi, I'm having the same problem here. I want to use concrete structural columns and beams inside the walls I put them there but they wont show up) and I also want to have columns with plaster finish.
First, to make a column visible that is hidden within a wall, use the "Unjoin Geometry" tool on the column to seperate it from the wall. Second, to put plaster on a column, you may use one (or more) of the following options: - Edit/duplicate the existing family and add the "plaster" layer to the model. (family modeling techniques required which I will not explain. There are pleanty of tutorials available)
- Create a new wall type consisting of "plaster" only and surround the column with it. (This will require seperating the column from the wall as mensioned above.)
- Just add detail lines around the column to represent a layer of plaster.
Edited on: Fri, Dec 8, 2006 at 5:43:58 PM
Edited on: Fri, Dec 8, 2006 at 5:46:08 PM
2 Posts No Rating |
Thanks Normanoid! Nice help.
columns with plaster? |
Tue, Jul 4, 2006 at 6:29:22 AM
plaster on column? "really in trouble".. |
Tue, Dec 18, 2007 at 9:07:39 AM
How do I apply plaster to structural Concrete Columns |
Tue, Mar 4, 2014 at 1:09:38 PM
PLASTER WALLBOARD FAMILY |
Fri, Mar 24, 2017 at 10:10:46 AM
Single Timber stud to double stud wall doesnt wrap the plaster at the end. |
Wed, Aug 8, 2012 at 5:18:19 PM
Members: | 2118811 | Objects: | 23205 | Forum Posts: | 152310 | Job Listings: | 3 |
